Energy Suspension Tranny Mount (too tall?)
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
Hey guys,
Just put an energy suspension transmission mount under an fm146 (2.9l 1989 BII). It is a bit taller than the OEM. Had to cut a bit of the cross piece on the body to allow the transfer case flange room to rotate. Anyone have any experience with these mounts?
19Walt93
4,467
Canaan,NH
351
3"
235/55R16
Is the mount specified for the truck? Raising the back of the trans will change the driveline angle and could cause vibrations. A stiffer mount will also transmit more vibration into the chassis.
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
Yeah, it was designed for it, even said so in the literature that came with it. I have lifted a few trucks in my day so i am very familiar with the vibes your are speaking of! I already have a 2 inch lift on, so the chance of vibes is growing for sure - the good news is the engine is running so crappy right now I couldn't tell if there was vibes at all LMAO. I have had great luck with that company, so I went with them. I may go back to a standard OEM style unless someone has some experience with these.
Junk Collector
Truck of Month
4,802
Rapid City SD
Is it possible that your OEM trans mount was just squished down from age, thus the height difference?
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
I honestly didn't think of that - slap on the forhead. It might actually only be 3/8 inch or less higher - I only had to bend the body metal about that much. For those of you running OEM mounts, how close is you transfer case output flange to the body?
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
I would check your body mounts too. Maybe your body is sagging a little.
Junk Collector
Truck of Month
4,802
Rapid City SD
I don't recall how close the t-case was to the body on any of my Bronco II's, it's miles away on everything else I have now. I agree with sno, I'd be checking body mounts, especially the rear ones. You should have way more clearance than that.
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
Let me check the part number on that new mount before I get too crazy. I'll let ya'll know
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Slappy wackies makes happy pappies
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
On a serious note, Dirtman, I see you are a health care professional. Thanks for what you do! These are weird times and we need folks like you for sure
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I haven't been an EMT in a looooong time, I tend to lean towards the villainous side of the spectrum now adays.
19Walt93
4,467
Canaan,NH
351
3"
235/55R16
It always sucks the first time a doctor says "that's to be expected in a man your age".
Seriously, the flange shouldn't be any where near that close to the floor, something's wrong.
