Electric Radiator Fan Upgrade. Some Advice 93 Ranger 4.0 XLT 4x4
Angry Possum
No Fat Chicks, Truck Will Scrape
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
Sometimes you eat the bear, sometimes the bear eats you.
I'm deciding on removing my stock Radiator Fan, and installing an electric radiator fan or a double fan kit. Question is, Is it worth doing this Mod for better cooling and HP gain etc? And are there any good fan manufacturers/company's that you may have experience with or recommend? My Ranger runs a little hotter than normal, with the AC on in NY traffic, but only in the summer months even after I flushed it and changed fan clutch. If you have experience with this, please elaborate.
rumblecloud
1,122
48022
Ranger Splash
1-1/2 inch front leveling
Stock
What's the worst that could happen?
8,370
Reverse the heater hoses at the firewall, do this every 2 years, engine will run cooler and heater core will last longer
When you start cold engine you should hear the fan noise for a few seconds, fan clutch is cold locked
You should hear that same noise when driving in slower traffic on hot days, means the fan clutch is locked, pulling more air thru radiator and more air circulation in engine bay
If not then could be fan clutch is not working as designed or center of radiator is clogged up and not warming up the clutch
If you don't have a fan shroud then you will get hotter coolant temp when in slow traffic on hot days
E-fan is the only thing that can increase MPG AND horse power, ain't much but ain't 0 either
If it seems to only run warmer with AC on then you could add a condenser e-fan to start with, usually a simpler install, and easy to find at wrecking yards, they are fairly generic
Just need a relay that is activated by AC compressor 12v wire, so simple wiring, no temp sensor to deal with
Kira
62
Champlain + Hudson Valleys
Ford Ranger FX4
How do you break / release the hose clamps on the firewall? I don't want to just shove a screwdriver into it and twist as that'll bend the heater core's pipes.
Is there a tool for that? Just plain cutters?
8,370
Pull back the clamps
Use a pair of pliers to twist the hose to break it loose, do it at different points along the length of the heater core pipe, you will feel it moving don't need to squeeze it too tight, just enough to grip the hose
Hoses are a bit like the Chinese Finger puzzle(trap) in that if you pull on them to remove from the pipe they get TIGHTER, lol
So get them to turn on the pipe a bit and then use the screwdriver on the end of the hose to slide them off
Spark plug boots have the same issue, the harder you pull the tigher they get, lol
Kira
62
Ford Ranger FX4
Sorry to be dopey (birth defect I've learned to live with) but isn't there a shoulder or barb ?
If the clamps just pull back, what keeps 'em in place day in and day out?
8,370
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
First of all, listen to RonD
Besides that I will share my experience. I switched to electric then switched back. Didn't wanna risk the bulletproof stock setup. The electric kept giving me little issues, maybe due to my incompetence, but it just seemed fickle and less efficient. Yes it did gain free up power losing the clutch fan though. I miss that part. I may switch back in the future.
I have the same ranger as you and live in socal (its hot).
Lefty
1,847
Saint Paul, MN
Ranger Edge
It's a small but nice improvement. Maybe mileage and horsepower is better but not by a lot. it would certainly regulate temperature better.
Angry Possum
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
@RonD The Radiator is new and the clutch fan is new. I did a full flush about 7 times in one day, (Yeah OCD) when I bought it last year. Only thing I didn't change was the TStat.
PS I'll try the heater core hose switch today. Thanks
Lefty
1,847
Saint Paul, MN
Ranger Edge
And, yes. That flush is important. I did it twice. Why not? This is the perfect time.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
You might just need to burp the system. This was boning me until I did a good proper burping. A lot of air came out and cooling system works tip top now.
8,370
Engine cooling systems have two sides, engine side, radiator side, they are separated by a thermostat
Heater and its hoses are on the engine side
The heater hose that comes out on or near the thermostat housing is a high point for the engine side of the cooling system
Its the best hose to remove at the heater core port to let air out while refilling
But pulling either hose at the firewall will let out the air, because heater core has a failsafe passage at the top between the two ports, so air can easily cross over to either port and be cleared while refilling
The closed thermostat won't let air out when refilling, which is why air gets trapped in the engine side
(Some engines use a thermostat on LOWER radiator hose, these usually don't run into "trapped air" issues)
Some thermostats have a "jiggle valve", yes thats the name, its a loose metal pin that sits in a hole in the thermostat plate
Jiggle valve can let air out, slowly, as you refill the system, the loose metal pin is there to keep debris from clogging this hole
i.e. if you have a coolant leak in the engine side, it will leak coolant but can also suck in air during cool down
The jiggle valve will allow that air to get to top of radiator prior to warm up and thermostat opening
If thermostat is mounted vertically then jiggle valve should be at 12:00 position to be most effective
Broosedamoose
115
South East Massachusettes
4.0L SOHC
31 x 10.5
Coming in second just makes you the first loser!
I went to the junk yard and pulled a fan out of a Taurus. It's plenty sufficient to cool the engine. At first I had it hooked up to a t-stat and the A/C compressor with two relays. However, the relays kept failing on me! I even bought heavy duty, waterproof relays good for 120 Amps but even those failed. So, I just recently ditched the t-stat and hooked it up to run whenever the engine is running. I also moved the relay inside under the dash. This is the relay I'm using now and it has held up for quite a while now: Relay
