electric fan
black06xlt
i have a 2006 with the 4.0l im wanting to the clutch fan and replace it with an electric fan. i got an electric fan from a 2002 ranger with the twin cam 2.3l would that fan work on my 4.0l?
Marty'70
West-central PA.
2.5
Let !e know if it does and how you did it. I have e one from a 01. And I have an 04 I'd like to put it in
Sent from my QMV7B using Tapatalk
black06xlt
will do marty... i ordered a fan controller and a radiator hose adapter just waiting on parts to come in
black06xlt
i have heard bad things about the controllers with the probe. i found on amazon a derale fan tempeture switch that requires a hose adapter also on amazon that uses a sending unit to tell the fan when to come and when to shut off
Marty'70
West-central PA.
2.5
Cool just wondering. Do they come with wiring and relays to install?
black06xlt
the kit does come with wiring relays fuse and all needed hardware for the install
Broosedamoose
115
South East Massachusettes
4.0L SOHC
31 x 10.5
Coming in second just makes you the first loser!
Those controllers are junk! Don't buy it! I went thru two of them before switching to something else. They quit working after a month or so!
This is what I've had for a long time now and it work awesome! It's a bit more expensive but it can do a lot more!!
Fan Controller
tcbaklash
Central WA
I went with the Flex-A-Lite kit. Comes with a direct-fit fan, controller, and 10A fuse. You have to provide your own relay unless you want it to run with the engine off.
