eightynine4x4
- Oct 15, 2020
- 178
- New York
- Ford Ranger
- Engine Type
- 2.9 V6
- 2WD / 4WD
- 4WD
- Total Lift
- 2.5" Suspension
- Tire Size
- 31 x 10.5 x 15
This thread will get back to topic after this thermostat is installed!
But a fun update is that the reverse bit I have has snapped inside the bolt carcass. I had a good pilot hole drilled through it and now it’s filled again, lol. It’s also MUCH more difficult to drill into this new material, so I’m abandoning that.
So I think I’ll be creating a whole new bolt situation just next to the carcass. I can ignore the carcass because it happens to be flush with the water output’s surface when mounted.
Will first drill a hole through the water output piece, then will line it up on engine and drill a hole through into engine block behind it, then tap the hole for 8-32. Will probably expand the hole on water output piece a smidge so that alignment doesn’t have to be completely perfect.
If anybody has any insight or guesses as to how far I can go into the engine at a certain spot adjacent to the dead bolt, I’m all ears. I’m thinking just to the left, practically touching the carcass. Will probably restrict myself to like 1/2” depth. Obviously I don’t want to drill into the water flow cavity itself.
