- Feb 11, 2021
- 2,909
- Seattle, WA
- Ranger XLT 2WD
- Engine Type
- 3.0 V6
- 2WD / 4WD
- 2WD
- My credo
- Keep your mind like an umbrella, it only works if its open... Continually learning.
Well as it begins, there are a few items that need to be addressed for my Sport Trac. Don't actually have time until this Friday to start troubleshooting but I've been looking / researching the items.
So the first big issue is the 4WD operation. The "4x4" and "4L0" lights on the dash do not come on when the truck is started for the bulb check. Fixed, poor connection at 4wd selector switch.
I went to the tech section Transfer Case Troubleshooting - The Ranger Station Under the Trouble Shooting for the 1995 & Newer Transfer Cases:
Symptoms:
1) When starting vehicle, the “4WD” and “4WD LOW” lights on dash never illuminate. NO LIGHTS
2) After turning 4WD switch (knob on dash) there is no response at all, 4WD light on dash never illuminates and no clicking. Not lighting or flashing
3) 4WD will not engage. Not engaging
I plan on going through steps 1-5 on Friday.
Next Item will be the Power Mirrors being inoperative. So, I'll be checking the fuse for that then testing the switch for power and operation. Fixed bad power mirror switch.
I noticed that a couple of body mounts were toast so those will be coming soon.
Missing antenna and jack. I'll grab those from the junkyard next time I go.
Tailgate handle is hard to operate. Suspect linkage is either bent or plastic clips are starting to fail. Fixed. Clean and lube latch mechanisms.
Thermostat housing is the plastic one, so that's added to the list.
Tensioners as well.
No oil on the driveway but undercarriage is wet. Need to clean up and check for leaks.
Change fluids and filters.
Replace burned out dash lights. 4x4 switch back light, rear window switch light. CC switches on the r/s of steering wheel are out, but I image that would be a whole switch replacement.
I'm sure I'll find more down the line.
Symptoms:
Tensioners as well.
