OHM testing for TFI module here:
https://www.therangerstation.com/tech_library/TFI_Diagnostic.shtml
Module is disconnected from distributor to test the 3 "sensor" connectors
The Hall effect sensor(pickup) inside distributor needs to be test when TFI module is unplugged, these rarely fail but its possible
Loosen distributor but MARK where it is, you will need to turn the distributor
The Hall effect sensor detects a permanent magnet mounted next to it, there is a wheel with "vanes" attached to distributor shaft, it rotates the "vanes" so they pass between the Hall Effect sensor and the magnet
When a "vane" passes between it cuts the magnetic field, when there is no "vane" so open, magnetic field is back
The 12volt Hall effect sensor Pulses 12v on then 12v off, as the wheel spins
12v and ground should test as under 100ohms, its just a coil of wire
signal wire to either 12v(or ground) should show high then low ohms as you turn distributor so vane cuts off magnet then "window" restores magnetic field
