- Oct 20, 2009
- 221
- Utah
- Ford F150-Stang
- Engine Type
- V8
- Engine Size
- 4.6 Triton / 5.0
Here's a pic of that tape (now that I'm not on Crapatalk).
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
I've seen commercial mudders use spray glue and plastic outside corners. It saves one step and can be used on radiuses.I used the corner bead tape I was talking about on outer corners in my bathroom. Inner I still used regular paper. It beats the piss out if nailing the old school stuff in place and uses a lot less mud.
Sent from a Commodore 64 using a 300 baud modem
Ooops...didn't see this part...lolI had a guy come look at it today who has been doing drywall for 40 years.
1. He said the plywood should've come down from the ceiling first.
2. The drywall on the ceiling is run the wrong direction. He said the long edge should be across the joists not parallel to them so the butt joints are on the joist. He also said on a ceiling you need cross braces in between the joists to tie them together as well. (I can't tell if it has any because of the insulation) He said since this was a carport there probably aren't any.
3. He said 1/4 is too thin for a ceiling. Said it isn't strong enough to hold its own weight and eventually will sag like the dickens unless he put a ton of screws in it.
This is what is going to happen. Not selling.Maybe need to tear it all down and do some cross bracing and apply some strapping across the joints...unless you plan on selling soon...
That would be a lot of extra work, and it would only really be a help if the edges of the drywall were not beveled. But since the long side edges of pretty much all drywall available are factory beveled, it's a waste of effort. The short sides don't matter so much because you should never line up joints, sheets should be cut and lapped, much like you would do sheeting on a wall or roof. Short side should end on a joist or stud and the long side should be perpendicular to the joists or studs - drywall like sheeting (plywood, osb and some paneling) has the most strength when used in that direction.This is what is going to happen. Not selling.
I did some googling on hanging drywall on a ceiling and I saw more than one "how to" that said that the butt joints should be BETWEEN the joists and a board with shims on the edges used to secure the butt joint so that it bows slightly upward. Sounds like a bad idea to me and it sounds like a lot of extra work. http://www.finehomebuilding.com/PDF/Free/021174058.pdf
Wow, good article...except that part about the butt joints being away from the bracing and strapping...but I would have to read more on it to understand the logic of that...I've always seen it secured to strapping or joists directly...and thought it made much more sense to secure those ends and then work them with the mud to smooth them out...This is what is going to happen. Not selling.
