drum brake backing plates
ForOffRoadDriving
18
HIGHLAND, MICHIGAN
FORD
3.0L
does anyone know if 10" drum brake backing plates from a 8.8 will bolt onto a 7.5" axle or are the tube diameters and bolt spacing different?
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
It will work.
BillB
2.5
Just replaced one of mine....I always had trouble w/ the 10" since new, locking up.
If I had the $, I would replace the 10" w/ the smaller ones....I hear that fixes the problem.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Direct swap.
ForOffRoadDriving
18
HIGHLAND, MICHIGAN
FORD
3.0L
its already got the 9" backing plates but since im running 30" tires i wanted to go with the bigger brakes. the current axle has 10" brakes on it so i was just going to swap all of the brake stuff over, but then ill have a good axle that needs more parts before it can be used again. i would like to keep it complete so that in the event that my new axle meets a gruesome fate i can just bolt the old one back in.
AllanD
134
East-Central Pennsylvania
1987... sorta
'93 4.0
Ranger/Aerostar backing plates will work.
Explorer drum backing plates use a different pilot diameter and mounting bolt pattern.
