Drivetrain thumping
Kona
06/2014 OTOTM Winner
Canada Military - Veteran
ASE Certified Tech
Ham Radio Operator
Kamloops BC
7"
35x12.50x15
Hey folks, my 91 Ranger 4x4 (4.0L ) just started making a uneven thumping noise at speeds over 25 mph / 40 kph , seems like it is inline with the transmission bell housing (thus posting here ) though a little under the front floor.. No sound at any rpm in 1st 2nd or neutral , sound is there with engine off in neutral coasting . Hubs are free , transfercase in 2whl drive . Transmission was a spare installed about a year and 1/2 ago. We did have problems sliding the shaft into the pilot bushing . I have checked the bottom 4 transmission bolts for tightness and they were good .
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Does your driveshaft have the goofy balancer on it (big disc at the front yoke)?
They are notorious for falling apart and making a clunking / thumping sound.
ericbphoto
Overlander in development
16,598
Wellford, SC
3.0L
6"
Somebody has taped a cat to your drive shaft. At low rpm, no problem. At higher rpm, centrifugal force throws his tail out so it hits the floorpan. The tail will break off after a week or so and the noise will go away.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Kona
ASE Certified Tech
Ham Radio Operator
Kamloops BC
7"
35x12.50x15
I did just get brand new tires , a suggestion was separation so I will throw other tires on and check
Junk Collector
Truck of Month
4,800
Rapid City SD
Bad u-joint? Do you still have a two piece rear driveshaft? I just rebuilt a rear two piece that had a locked up u-joint at the t-case... it was so bad that it destroyed the carrier bearing and felt like the front end was coming apart at 5mph and faster.
