Drivetrain thumping
Kona
06/2014 OTOTM Winner
Canada Military - Veteran
ASE Certified Tech
Kamloops BC
7"
35x12.50x15
Hey folks, my 91 Ranger 4x4 (4.0L ) just started making a uneven thumping noise at speeds over 25 mph / 40 kph , seems like it is inline with the transmission bell housing (thus posting here ) though a little under the front floor.. No sound at any rpm in 1st 2nd or neutral , sound is there with engine off in neutral coasting . Hubs are free , transfercase in 2whl drive . Transmission was a spare installed about a year and 1/2 ago. We did have problems sliding the shaft into the pilot bushing . I have checked the bottom 4 transmission bolts for tightness and they were good .
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Does your driveshaft have the goofy balancer on it (big disc at the front yoke)?
They are notorious for falling apart and making a clunking / thumping sound.
ericbphoto
Overlander in development
16,613
Wellford, SC
6"
Somebody has taped a cat to your drive shaft. At low rpm, no problem. At higher rpm, centrifugal force throws his tail out so it hits the floorpan. The tail will break off after a week or so and the noise will go away.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Kona
ASE Certified Tech
Kamloops BC
7"
35x12.50x15
I did just get brand new tires , a suggestion was separation so I will throw other tires on and check
Junk Collector
Truck of Month
4,807
Rapid City SD
Bad u-joint? Do you still have a two piece rear driveshaft? I just rebuilt a rear two piece that had a locked up u-joint at the t-case... it was so bad that it destroyed the carrier bearing and felt like the front end was coming apart at 5mph and faster.
