- Feb 28, 2001
- 4,371
- Dayton Oregon
- Ford
- Engine Type
- 2.3 (4 Cylinder)
- Engine Size
- 2.3 Turbo
- 2WD / 4WD
- 4WD
- Total Lift
- 6
- Tire Size
- 35"
Ok, this is for my '97 F350 with 350K miles on the clock... or thereabouts as this is about the speedometer not working...
This system works by reading the reluctor wheel on the rear diff, it's all electric and programmable with the right button sequences (but you only get a certain number of chances from what I've read... it's only reading about 5% fast so I'm not screwing with it).
Anyway, I've had the truck for around 5 years, around 4 years ago was the first time the speedo quit on me, it just gets intermittent, sometimes will work til about 35mph then nothing above that, sometimes flaps full scale (IE goes from zero to max flapping...), speedo and odometer when it gets confused are zero so I have to drive off the tach... It quit on me again this april when I spent 4 days in the high desert in Oregon, went to the Oregon coast to play in the sand where it was overcast over the weekend and the speedo started working on the way home...
I've heard of dry climates being tough on electrical connections, what's the fix? The connection at the back of the speedometer is the issue which is a non sealed 8 pin connector. I spent 20 minutes trying to get the pins out a few weeks ago unsuccessfully, I'll give it another shot if taking it apart and tightening the contacts a little will help, but if just spraying some contact cleaner or something will work better and adding dielectric grease or something will work I'm open to suggestions...
I tell ya, when you have two fuel tanks, no speedo, no odometer, and the bigger of the two tanks doesn't have a working fuel gauge and you are towing in a mountain pass it's somewhat nerve racking...
Thanks for any help! Sorry for being long winded...
