Door locks problems
98fordf150
Wichita Kansas
98 f150 XL door locks hardly ever work. I have to wiggle the key back and forth for at least 2 minutes to get them to unlock either door. Tried spraying penetrating lube into the key slot opening, but that didn't help at all. Any suggestions? Anybody??
8,370
Need new lock cylinders or your current keys are very worn down so don't push up and down the release pins
Keys do wear out, if they no longer have sharp peaks and valleys they are worn out
Drivers door lock usually wears out first, so if your key also has a hard time on the passenger side lock then I would say its the key that's the problem, a locksmith can sometimes cut a new key restoring the peaks and valleys, can't do that with a simple key cutter machine, it just cuts the worn out pattern
You can get new door lock cylinders with 2 new keys, but would have a separate ignition key(current key)
Or you can get a full lock set, 2 door lock cylinders and 1 ignition cylinder with 2 new keys, BUT...............1998 F-150 may have PATS, passive anti-theft system, if thats the case the new ignition keys would have to be added to the system by locksmith or you using Forscan software
98fordf150
Wichita Kansas
Thanks Ron. Yeah, that's exactly the problem. The key is severely worn and I knew the key maker probably would only be able to duplicate what's left of it. Guess it's time to stop being a cheapskate and buy new lock cylinders.
8,370
You can check with Ford dealer using your VIN, and some locksmiths have access to that as well
With VIN a dealer can cut an original key, so not a copy an original
Problem is they usually only have that info going back 15 years from current year, but its a free call :)
You have to bring in the vehicle or the title to pick up a key made using VIN, just FYI
98fordf150
Wichita Kansas
That's a great idea. Thanks for the info!
98fordf150
Wichita Kansas
Hey Ron, I decided to try and replace the door lock cylinders instead of paying for a key to be made. Reason being if I have to remove the cylinder anyway I can buy brand new ones for right around the same price as having a key made. I had the door panel off today and wasn't sure how to go about removing the lock cylinder. Any suggestions?
8,370
Never did that on an 1998 F150 but if the cylinder is part of the door opener/handle then you will need to pull out the whole unit to swap the cylinders
Google: 1998 ford f150 removing door lock cylinder video
There are a few videos on replacing the handle and/or cylinder
98fordf150
Wichita Kansas
98fordf150
Wichita Kansas
I have looked all over the internet and I find nothing vehicle specific for my truck. There are plenty of videos on ford rangers, or door handle removal, etc., but I find nothing for 1998 Ford f150 XL with manual door lock cylinder removal/replacement. Crazy!
8,370
If key cylinder is part of the handle then you need to remove the handle to change the cylinder
Door lock Cylinders do have a left and right, the plastic "arm" can be installed either way so match the old cylinder
