Door lock conversion
rebelkid
San Antonio, TX
Mazda
Installing auto door locks and auto windows pulled from a ranger, verified the window motors worked before install, but silly me forgot to verify the door locks worked >_<
Issue: both door lock actuators click but do not move the lock. Currently have it grounded and have a extra wire i'm using [fused] straight to the batt to test.
Bad actuators? any diagnosis I can do to verify?
Thx
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
Are they installed or you doing in free air, sometimes the rods can binned up in the door allow the actuator to move
rebelkid
San Antonio, TX
Mazda
already installed....when using the outside door handle, inside handle, and lock stick thing on top of door, everything moves freely, tho drivers side is a bit rough
snoranger
Professional money waster
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
You have 1 wire grounded and touch the other to power? Correct?
Switch the wires. Maybe you're trying to push the actuator toward the direction it already is. (IE... Your trying to unlock an already unlocked actuator.) They need power and ground reversed to reverse the direction.
rebelkid
San Antonio, TX
Mazda
im just using 2 wires to jump it currently, and i have tried both directions, same result....and when say, trying to lock when already locked, it makes no sound [assumed that was normal]
snoranger
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Sounds like you got bad actuators.
rebelkid
San Antonio, TX
Mazda
Saddness....that was what I was fearing....since manual locks work for the time being ill just leave it be till I can cough up some new actuators
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
i have the cheap 10$ actuators from ebay in my truck and they have been working fine except my drivers door binds up, and this had lead to the death of the actuator
rebelkid
San Antonio, TX
Mazda
good suggestion, i'm getting ready to go on a trip but when i get back, ill have to nab 2...
