Does this look right?!
BiggSherm1988
U.S. Military - Active
57
Germany
Ford/Ranger
none...yet
not for me
I'm in need of a technical inspector lol. I didn't have much to go off of because they basically fell apart.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,509
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
They look spot on to me...
Did you put small dabs of lube on the backing plate where the shoes ride and lube the star wheel adjuster be fore assembly?
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
I always check by making sure the adjuster works using a flat blade screwdriver behind the backing plate to turn it.
ericbphoto
Overlander in development
16,663
Wellford, SC
3.0L
6"
and make sure you put the star wheels on the proper sides. If I recall, one is left-hand thread and the other is regular. If you mix them up, the adjusters won't work.
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
I forgot to mention this is why I make sure they work from the access slot as if the drum was on
BiggSherm1988
57
Germany
Ford/Ranger
none...yet
not for me
Alright now I need to double check. FML. I believe I put the adjuster on wrong if there is a driver/passenger side. I haven't fully buttoned everything up yet, the sky took a piss on me as I was putting on the final springs. I just tossed the drum and wheel back on to get it off the jack before the storm hit. tomorrow I will put some grease on the mentioned spots and double check that star adjuster. the stuff I took off was basically fucked. The star adjuster had about 4 teeth left, it looked like a meth head.
Uncle Gump
Token Old Guy
13,509
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
If you just take the hold down springs off each side (round ones with the pin) the shoes will come off the backing plate far enough to put a little lube on the backing plate bosses.
Before you pull things apart to check the star wheels.... just rotate the star wheel buy hand upward and see if the adjuster expands. If not... you put them in the wrong side.
BiggSherm1988
57
Germany
Ford/Ranger
none...yet
not for me
Does it matter if the star adjuster is in one way or the other? as long as the star adjuster stopping mechanism holds the teeth does it matter if you rotate it up to adjust or down? The adjuster I took off rotated in a downward motion to tighten the shoe slack but the one I put in is rotating up to adjust the slack (puts tension on the brakes). I'm still going to take a second look just to make sure. i just wanted to see if the direction of adjustment actually mattered.
Uncle Gump
Token Old Guy
13,509
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
With that adjuster lever... you what the star wheel to expand rotating up. If it was the other way... the shoes would move inward and loosen the brakes.
So yes... it matters...
pjtoledo
2,989
Toledo Ohio
Fords
3.0 2.3
yes it matters.
the adjustment happens when the arm pushes up on the star wheel. I type slower than Uncle Gump.
some star wheels have one-direction teeth, the arm can push up then easily skip back down to resting position.
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Its no biggie, I've gotten the adjuster backwards a few times, it pops right out with some finagling.
BiggSherm1988
57
Germany
Ford/Ranger
none...yet
not for me
Got both sides done. I rechecked and greased everything. I took the time to knock out the diff fluid and cover. living in a place that uses salt is very destructive on vehicles. I hate that Germany uses so much salt in the winter. Thanks for the info.
