Does a steering stabilizer really help?
TeamExploder
McClure, Pa.
FORD
4.0 OHV+SOHC
My 94 drives alright but when hitting bumps or dips in the road the steering does tend to pull in whatever direction, (I know its not suppose to drive like a cadillac) it has had an alignment and everything so I was thinking maybe adding a steering stabilizer would help but would like to hear from others as to if it has helped you. I think James Duff makes a kit and maybe Rancho, still need to research that.
NMB2
July 2010 OTOTM Winner
22
Cody, WY
5.0 V8
waste of money. if its strong enough to pull your steering enough to bother you. Its not going to fix it.
TeamExploder
McClure, Pa.
FORD
4.0 OHV+SOHC
It doesn't bother me, just wanted to see if I could improve it any.
You sir have bump steer. Set your tire pressures to the correct spec (35 PSI) and then find and replace your worn out ball joint, tie rods, and or pitman arm and tighten up your wheel bearings to take all the play out of your steering system.
Steering stabilizers only help to hide existing problems, unless you have 6 inches of lift and +35 inch tires.
TeamExploder
McClure, Pa.
FORD
4.0 OHV+SOHC
I have the tire pressure set at 33psi. I'll do a steering and suspension evaluation. Shocks come this week so will look at it when the weather allows. Thanks
ranger
Pittsburgh,Pa
Mazda B4000
2.9L
i have 7inches of lift and 33's on my 88 ranger and the steering stabilizer helps.
You also have a setup that actually needs a stabilizer. In stock form they should be unnecessary.
Beanmachine7000
5
Tennessee
The OP's Explorer have 6" of lift and 33's... Still, it would be more beneficial to attempt to fix the bumpsteer by correctly aligning the tie rods (I know it wont be perfect) than to hide it with a steering sabilizer...
TeamExploder
McClure, Pa.
FORD
4.0 OHV+SOHC
Thanks for the information, I will fix what needs attention first and see how she does but before I bought the truck the owner had an aligment done at a 4wd shop in his town so everything might be ok. But probably still get a stabilizer James Duff sells the kit and stabilizer for around 60 something so its a cheap mod for helping maintain good steering.
Well roll me in creosote and set me on fire, he does. A stabilizer might be in order, but ONLY if all of his front end parts are nice and tight. 6" usually shouldn't need a stabilizer.
The Jester Race
68
Sacramento, Kalifornia
Ford, BMW
2.9, 4.0
Short answer is yes. But they are often used as a bandaid to cover up worn out steering components or bad steering geometry. Larger tires(over stock) put more leverage on your steering and suspension components, and tend to exaggerate every bump and pothole in the road.
Post a picture of the steering setup.
-Jester
TeamExploder
McClure, Pa.
FORD
4.0 OHV+SOHC
I will post a picture of the steering tomorrow.
8879ford
i have one cause they do help stop bump steer.....or at least weakeen it
TeamExploder
McClure, Pa.
FORD
4.0 OHV+SOHC
Here are pictures of the steering setup. I've IFS for so long but this all looks correct to me.
99RangerKrazy
Kennewick, WA
That's some pretty bad steering geometry. The tie rod should be completely horizontal/parallel to the axle beam. Do you have the FA600 pitman arm? It doesn't really look like it. If you don't, getting that would help. However, you may need to upgrade to a new steering set up, like the Stonecrusher steering.
