DIY maintenance
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
A lot of guys do that.
I use it (waste motor oil) in my fuel tank.
And a quart of lucas instead of bar and chain in the crank case.
I think the car and chain guy meant he used bar and chain as an additive.
Only thing I would do to an eb is a catch can....they will run as long as anything.
They are low speed, and programmed specifically for idiots to use them. The inferred logic is epic.
The 2.3 is a beast...like mentioned based on the Mazda L and awesome. If you had a Mazda 3...2.0 or 2.5....can't see how you could not like the Mazda platform. And I am a V8 guy.
Define diy maintenance? Because it pretty deep around here.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
I use waist motor oil in my saws.
Now we've come full circle.
You have them suck the beer storage cells out of your belly and waste beer lube on you saw!?!?!?
Evil.....pure diabolicle evilz.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Here's my take on oil...
The fancy nerds at the oil companies who do nothing but study oil have went ahead and made all different types of oils based on their specific uses, then they were nice enough to put a label on those oils so us mortals can decipher their purpose. You don't need to wonder if chainsaw oil would work better in your motor than motor oil because those clever engineers already figured it out for us and that's why they labeled them the way they did.
sgtsandman
Aircraft Fuel Tank Diver
12,646
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Not to mention the manufacturer has done the work (theoretically) on what works best for their product.
If I remember correctly, bar and chain oil is just 30 weight oil with an additive to make it cling and minimize fling.
I can see the theory on using used motor oil on a chain saw but it is going to messy. ATF, I think would be too thin.
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
I have different bar and chain oil for summer and winter, summer oil won't flow in the cold and winter oil runs like water in hot weather.
MikeG
752
central Texas
B4000
2"
235/75r15
You have to crank the bar oil delivery back to use ATF, and yeah you go through more of it for sure. Makes the sawdust a lovely shade of red ;)
Sidewalk
Norco, CA
Ford Fiesta
1.6
#DontFollowJosh
Guess I missed a notification here somewhere...
TL;DR: I took the Bronco off my list.
Still considering options, but one of them is a stripped down Jeep JLU (space for my bike inside). The idea of having a much simpler vehicle appeals to me. No turbo, no power windows, solid axle, etc. Millions of parts you can buy for them if I want to change things later if I really want to. Port injection is nice too. This vehicle purchase will be for a do all utility vehicle, not necessarily a trail rig which is why it's also competing with a Subaru Crosstrek. I wish Subaru had more manual options, also wish the Ridgeline had a manual option.
As for oil, the Fiesta didn't burn a drop with 10,000 mile oil changes. My ex's F150 has 200,000+ miles on the 4.6 with 5w-20 and we beat that thing well (the mirror is still taped on after a cow broke it off). I'm not worried about out smarting people with PhD after their names (tends to be the dumbest people who think they can) who design all this stuff.
As for "maintenance", in my mind that is stuff that you would find listed under "maintenance" in your manual. When you open your owners manual there is a whole list of stuff for you to maintain and how and when to do it. I just did the glow plugs and up pipes in my 7.3 Powerstroke van (that sucked), those are technically not maintenance items so I wasn't concerned with that. But the belt is and that's a pretty simple swap. Likewise, timing belts are a maintenance item and on the Fiesta it was easy, on the PT Loser my ex had it was easier to pull the engine to change the belt, which is rediculous. So, DIY maintenance is stuff you normally need to do to keep your vehicle running, repairs are a separate category.
Old turbos were known for "coking" the bearings. After driving hard the turbine would be hot and the sudden stop in oil flow would break down the oil in the bearings from heat soak. It was mostly solved by installing a coolant passage around the bearing to help manage temperatures better. Even still, I never hot shut down my Powerstroke, I always do a cool down if I was doing highway driving. But at 300,000+ miles who knows how badly it was abused and I don't have the resources right now to pull the body off to rebuild the engine, as I am homeless. I'm not worried about the engine failing any time soon though so I just have to keep up with random failures as I find them, most of which I can do anywhere.
Still undecided, I am trying to convince myself to wait for my final settlement before purchasing anything, but I probably won't wait as I want to dig into my van more and will need another vehicle for getting me out on the trails for running and biking (ultra distance runner and race MTB as a pro). I've decided I don't need a horse trailer tow vehicle as my horse is too old now to travel with, he's just a big dog now.
Unfortunately, the options for vehicles with a manual transmission are limited, and it sucks. Hoping this next buy will be my last (and only second) new vehicle. Alternatively, I could buy a beater and dump an ass load of money into my van...
JohnnyO
Moderator Emeritus
Forum Staff - Retired
2,840
Pittsburgh, PA
2.3 EcoBoost
1.5"
"220, 221, whatever it takes."
I don't know about the other ecoboost engines but the 2.3 in the Ranger calls for 5W-30 and of course, Recommends their synthetic blend.
I got a new-to-me 2020 Ranger today and it calls for 5w-30.
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
You get an attaboy for checking and a gold star if you read the manual, too. I've never talked to anyone who bought the new Ranger and didn't like it, enjoy your truck.
racsan
4,441
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
does the ford have a real manual still? Ive heard of some new vehicles (dodge?) coming with a dvd manual, I wouldnt even bother with that, Id just look up online whatever Id need to know.
sgtsandman
12,646
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Still has a paper in 2019.
