Hmm, ok thank you for the information. My issue is I only drive 8 miles round trip for work, so a new turbo charged ranger or bronco wouldn't be a good idea as a short range daily driver then. I don't drive out of town very often anymore so I guess I better skip the idea of a ranger or bronco in my future I don't want to have any issues, dealerships in my area are 35 miles away, and without any way to get home after having to drop off a vehicle for repairs, on top of that having no way to get a vehicle back to a dealer if it breaks down is not something I'd want to try to deal with. Its bad enough when I have a vehicle issue in town, but at least its only a 3-4 mile walk home depending on where I am in town at the time....I've had to make that walk several times...waiting 3+ hours for a wrecker where I live is very common...when my Jeep died last year on the side of a 2 lane highway during the summer I was stuck there for 4-1/2 hours waiting for a wrecker....so I can't chance stuff like that happening with a vehicle that would have to do to a dealer for warranty work, repairs, service, etc. Ran into that issue with my 08 Tundra and trying to get a rental car anywhere never seems to end well, there's just nothing out there.
The thing with the buildup on the valves, the 2.3 is direct injected, fuel is sprayed directly into the combustion chamber, not the intake port. So stuff from the PVC can accumulate on the intake valve, in severe cases it can make them run weird. There is a procedure for cleaning the valves and you can get a catch can that is supposed to filter it out (I need to check into one for our Bronco)
The early 3.5 EB was the same way. Eventually somebody figured out "hey this can be a problem" and the V6 Ecoboosts went to dual port, with an injector spraying into the intake port like they always have and one spraying into the chamber. This keeps the valves clean like apparently nobody knew they had been doing prior. The 2.7 in the Bronco is a dual port if you are concerned.
I am not overly concerned obviously.
The turbos I assume have oil that circulates through them, is that changed when you change engine oil or is that a separate task? Sorry probably sounds stupid but like I said I'm not a turbo guy, never owned anything turbo charged.
I do wonder why they went with turbo chargers instead of just supercharging them like Nissan did with the Frontiers several years ago? Is one better than the other?
Turbos have oil lines from the engine and use the engine's oil for lube.
Turbos are more efficient and simpler on the control side for an OEM.
I'd wonder really if you maintain them properly, which I am wondering how much truth there is in that statement alone for the failures that my aunt is always talking about at the dealership. I often wonder if many of those failures are due to skipped regular maintenance? I mean didn't Ford have some turbo charged car engines in the 80's that are still actually on the road to some degree, and being pulled off engines from pick a part yards to be put on RBV engines? So if that's the case I'd think the turbos would be fine, I bet the electronics probably go haywire long before the turbos & engines fail unless of course they're not maintained.
Sorry I still love the old trucks, but just extremely curious as to how things will hold up over time, cool you get a 3 year warranty but what happens when you have to have something fixed on these trucks after the warranty expires? Are the repairs really that much more expensive than an older vehicle truly? In the way of parts, I know labor rates at shops vary from around $75 to well over $100 an hour for labor where I'm at....but are parts for today's vehicles really that much more expensive in terms of replacement cost and the number of times they have to be replaced, like alternators, water pumps, etc. I know a water pump for my 88 Bronco 2 is like $50 or less for example.
The big thing is to not overestimate how good your modern engine is with modern oil. Ford kind of does it to itself to a degree too, even with my 2.8 (per the sales brochure) you can go up 7,500 miles on an oil change.
Lower middle of page 19:
And maybe in some lab condition they can, people look at the chart in the manual, underestimate what they are doing and run oil changes way longer than they should. They still do the same crap in new literature.
"I just have a short drive"
Short drives = short oil change intervals boosted or otherwise. Never fully getting up to temp is bad news for the oil.
"Oh, I live in the country the air is clean"
You also live on a gravel road with atomized rock in the air and your neighbor does fieldwork throwing dirt and dried powdered plants in the air.
Nobody thinks about stuff like that.
Glowing red for days on diesels with decent care turbos last darn near forever.
I opted for the 2.3 in our Bronco because it is a I4 and thus should be easier to work on than a DOHC V6, when its out of warranty, I will do as much as I can for repairs on it like I have the Edge before it. The thing will be a crappy race car or tow pig and as it sits it will have the most power of anything in my fleet even with the 2.3 (V8 F-150 included)
