dead miss under load
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Do unto others then Split-probasti me et chognuisti me
1987 ford ranger 4x4 manual trans(FM145) 2.9 litre. Ranger sit for a few weeks with stabil in the tank. It was running on all 6 cylinders when it was parked. Went through the top end last winter. Seems that it drops half the cylinders when it is under load. Idles rough sometimes. Seafoamed it, same thing. ran good for a few minuites then started missing. Has a little back fire, not much. It just started missing? Oh well, any suggestions from TRS would be appreciated. Dirty
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Seafoam does nothing.
Sounds like injectors are gummed.
You can try to clean them. Better to replace.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
I rebuilt them last winter. Wonder if the rust built up in the rail that fast and made its way to the screen in the injector.
8,372
2.9l
Its a TFI module problem, almost always
I would expect clogging injectors to stay clogged, so runs poorly, and stays running poorly, doesn't get better.......ever
If it runs better cold then also could be TFI, possibly O2 sensor, or ECT sensor
Try running at WOT(wide open throttle) and see if misfires clear up, if so change O2 sensor, the computer ignores O2 sensor(s) at WOT, just runs on preprogrammed mix tables
If it still misfires at WOT then TFI, always comes back to TFI, lol
If you have a vacuum gauge check engine vacuum, 18-21" is expected
Check vacuum line to MAP sensor, no leaks
rusty ol ranger
2.9 Mafia-Don
7,592
Michigan
177 CID
Try draining the gas and refilling with fresh before you do anything.
I know you used sta-bil but i would still start with the eaiset component.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,706
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Even with Stabil, gas goes bad. I agree, change the gas.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Gas was new two weeks ago, pure gas with stabil. I use it every time i fill it up. tank is half full. pumped enough out and ran it in the lawn mower. drain it anyway, use it in the tractor. Got a extra TFI, know how to test them off the truck. Thanks Dirty
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Changed gas, nothing. Changed TFI, nothing. Started pulling plug wires running(Shocking) to find the dead cylinder. Number 2 plug will not fire. Number 2 Spark plug wire is hot, ouch. Autolite 765. Now to find them.
8,372
Before pulling the plug disconnect coil spark wire, so no spark/no start
Then crank the engine over a few times
Now pull out #1 and #2 spark plugs
#1 tip should be WET with fuel, as should #2, if not then injector issue
So 2 birds with one stone
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Thanks RonD, wish i would have thought of that before the shocking experience. I bet your right on the injector on #2. seems it was dry when i pulled it out but had a good color. I don't remember if you can remove the injectors one at a time. I think i will have to remove the plenum. Going to try your suggestion when this rain lets up. Thanks Dirty
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Well it seems more than just number 2. three of the plugs were barely wet. injectors clogged again. They are all clicking but fuel is barely going through. I bet its a rusty fuel rail. Got to pull the plenum first. Dirty
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
three of the injectors had rust build up in the screen. Got them cleaned and spraying uniformly now. Guess i better change the filter to. Dirty
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Acid wash the rail.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Is that with muriatic acid?
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
