Damaged '02 fuel rail supply line
Balloonist
Albuquerque, NM, USA
Ranger 4x4
I have an '02 Ranger (XLT, extended cab, 4x4, 4.0 SOHC, AT - not sure which of that really matters). I was trying to replace the left side valve cover gasket, and I think I damaged the fuel line that comes from the left side of the engine, up over the front of the valve cover, and feeds into the fuel rails. Can anyone help me find a part number or suitable replacement for that?
I have searched Google for every set of keywords I can think of, and I've found very limited information. Apparently it's a fairly expensive line, but I'd rather pay for a new line than worry that my son's truck is going to have an engine fire from leaking fuel.
I saw a parts diagram that called it the "fuel supply hose," but no part number. I'm a little surprised that I'm having so much trouble finding information on it!
JMF661
120
Montana
Ford Ranger XLT
Stock
31” x 10.5”
That might be a tough one, not certain what kind of parts a dealership might have available for that year.
You might have luck on eBay, definitely a pick a part if you can find a later model ranger that hasn’t been picked clean.
edit: dang auto correct.
G8orFord
803
FL
4.0 SOHC S/C
Just the right size to touch the ground.
What makes you think it's damaged? It's a pretty hardy line.
sgtsandman
Aircraft Fuel Tank Diver
12,646
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
A possible option would be to hit up a junk yard or two and see if you can get the part from a vehicle on their lot.
Balloonist
Ranger 4x4
Like a bonehead, I mistook it for a vacuum line when I was pulling off the other vacuum lines that are above the valve cover. I got the outer sheath far enough back to see the steel later underneath, and that's when I realized my mistake.
The line may be ok (I have the trans out, and don't want to reconnect the battery just yet to see) but it begs the question of how much risk I'll take in my son's truck. He's 18 later this month, and not necessarily good at paying all the attention he should to odd smells when he's driving, so if a fuel leak starts up he might not realize it. If it were my truck is make a different decision, but like many parents I'm pretty protective of my kids. :)
G8orFord
803
FL
4.0 SOHC S/C
Balloonist
Ranger 4x4
It's probably fine, but like others have said, a salvage yard may be your best bet.
I believe this is the line you are looking for, but it ain't cheap new. https://parts.autonationfordwhitebearlake.com/oem-parts/ford-pipe-fuel-1l5z9e964ac
That is indeed the exact part. I don't know why I've been having so much trouble finding it - all my searches keep turning up the lines from the tank.
Does this use the little clip on the bottom end? I've never had to take one of those apart - how do I do that? (The fuel rail connections are both a pair of bolts through a flange, so that's easy enough.)
$200 for a new part ain't cheap, especially to pay for my own ham-fisted mistake, but I think I'll end up doing it for the peace of mind. I may call a couple of salvage yards first, though - my original 18-year-old part was fine until I got my hands on it, so another one is likely to be fine as well. It looks like the connection is down by the suspension, so I'm guessing it doesn't matter which wheelbase of truck or comes off of, as long as it's a similar year and has the 4.0 SOHC.
It must be my week to buy fuel lines. I'm due for new ones in my balloon, which goes in for annual on Wednesday. $900 for aircraft fuel lines, and suddenly my Ford parts don't seem quite so expensive!
Balloonist
Ranger 4x4
Thanks for all the help, everyone.
I ended up ordering the line new for about $200. Not cheap, but cheaper than an engine fire, and in the end it'll be cheaper than worrying about an engine fire.
I took the old line off last night to match it up to the picture, which was an incredible PITA. I have the tools to release the clip, so that part was easy enough. Getting the two bolts off the right-side fuel rail flange involved disconnecting multiple other lines and fighting my way around some of the wiring. And the clip that holds the line to the block on the left side - wow! I spent an hour and a half climbing on the engine, crawling underneath, and trying to get in from the fender well with a long extension. I was finally able to sneak my arm in past the upper end of the shock, but the way the bolt hides behind the power steering pump made it almost impossible. I'm hoping I can put it back on without unbolting the P/S pump.
Now I just need to get the reman transmission in and the valve cover gaskets replaced, and the truck will be good for a few more years. It just hit 200k (200,002 when the transmission went), and given the overall condition of the truck, I don't think 300k is an unreasonable expectation without a whole lot of work beyond routine maintenance.
