D44 ttb swap
dirtsquirrel
okay so i have herd lots of diffrent ways to to do a d44ttb swap and ppl saying it will or wont work, it seems to me that the easyiest way would be to extend the beams 1"? then i dont have to deal with shortening the shafts. also i got a 6inch lift in my ranger wondering if i were to do the ttb swap if it would be a benifit to put the 6" lift out of a f150 instead or will it not work?
red_ranger93
ontario
get some conversion brackets for it thats how i can do mine hopefully
prerunnerwannabe
10
UT
You have a 4wd so you can just bolt em in (I'm not sure about the radius arms though). It's not that big of a deal to shorten the passenger side axle is it? I would think it would be easier than extending the beams 1" either side at any rate. If you have been researching this then you know that you need to make a coil bucket spacer right? I am pretty sure you can just use your existing lift with the 44s. Good luck, and keep us posted about the project:icon_thumby:
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
I assume its just shorten the part that goes in the diff and get it resplined right? I still have a hard time picturing this, not saying that it cant and hasnt be done.
red_ranger93
ontario
To run the beams they need to be shortened or pushed outward 1" from stock dana 35 location I know where u can get the brackets so you don't need to cut the beam or shorten your axle shafts
prerunnerwannabe
10
UT
Those brackets would probably be the easiest thing to do. Whatever floats your boat I guess.
