D35 carrier break question
97fordrunner
9
New Richmond, WI
So i'm swapping gears on a D35 and I have a carrier that has the factory 3.73s on it and I have a carrier and third member that has 3.27 gears on it. Now just out of curiosity I tried installing the 4.56 on the 3.27 carrier knowing that the break is 3.54 and lower and 3.27 and higher. And I was quite surprised that my back lash and contact pattern was in spec the pinion pre-load was a little higher than used bearing spec but a touch lower than the new bearing spec. :icon_confused:
Next question, What is your guys preferred way of crushing the new sleeve? I tried a 20 ton shop press and put a decent amount of force on it and it gave about .02 but i didn't wanna go any further for fear of it going to far in a shot. Tried the impact and the Snap On doesn't have enough muscle I guess. So I clamped the yoke and took after it with a breaker bar and got it to pop.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
There is no carrier break on the TTB d35. All gear ratios use the 3.54 and up carrier in it.
As for the crush sleve, hold the yoke and turn it with a breaker bar with a long pipe on it. You want control over it, nice and smooth like.
97fordrunner
9
New Richmond, WI
Thats what I figured, Why in the world do they show a break then? thats gay. Anyways thanks for the info sir
CountryBoy78
Rice Lake,WI
Are you swapping out gears in your truck or another toy?
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
There is a carrier break for the Jeep d35 rear.
