d28/7.5 to d35/8,8
wantaranger
2.9L V6
im getting a d35 and 8.8 for my 89 bronco 2, the axles are from a 94(?) explorer. can i use the explorer shaft and just have it shortened up? because i read the flanges arent the same size? and same goes for the front driveshafts? are the flanges the same for hte front and can i use the same shaft? and are the shock mounts on the front the same? i read that they arent the same on the back so will i have to buy some more mounts or are they simple enough to make? and when i buy a lift kit, do i have to buy it for the 89 bronco 2 or for a 94 explorer? also are all explorer spring perches on the bottom of the axle or just the 95+ ones? and can i use the coils from the explorer for some more lift?
thanks in advance
Downey
Muncy, PA
you need the b2 front drive shaft to bolt to your tcase. you might need a u joint with 2 sizes but im not sure. i think you will have to swap out the rear flange on you drive shaft with the one on the explorer drive shaft but you will need your drive shafts.
  • ryan
    Forum Administrator
