Crossmember swap
Loanranger
4
Puyallup, Wa
1972
Ford/
Fordzuki
2.9/2.3
Well, I knew it would happen, and it did. The ranger (88 reg cab, longbed, 2.9, fm146) I have been building up for my dad to wheel has the trans crossmember with the bushings on the outside of the frame, and he came down pretty hard on it last trip out, and bent the whole thing back, smashing the frame bracket pretty good. SO I was going to swap in the crossmember out of the 83 donor truck, but it's 2wd, and so it won't work. The problem(s) are that it is not clearanced for the front driveshaft, the area that bolts to the trans mount sits up higher than the 4wd one, and the holes for the mount are too close together (If this was the only problem I'd just make new holes) SO I then went for the 99 4wd one I brought home from work, which is too wide for the frame. I knew it was too wide, but was hoping I could lop some off and make it work. I know there is a crossmember that will work, because I have heard of the swap on here before. I did a search, and came up with an Explorer one? What years will work? Is this the only one that will work? I like the tuck up in the frame design of the 2wd one, and I'm assuming the Explorer one is the same design? Is there a specific year ranger one that will work? If I can't come up with one on the cheap, I'll probably end up making one, it would just be easier to find one that is a direct swap. Thanks in advance.
Loanranger
4
Puyallup, Wa
1972
Ford/
Fordzuki
2.9/2.3
Well, I ended up making a crossmember out of 2"x4" tube, but if anybody has the info, it may help others looking to do the swap.
MAKG
19
California central coast
91-94 Exploders or similar year 4x4 Rangers ought to work. You will need to drill ONE hole in the bottom of the frame to secure it.
Evan
5
Stevens Point, WI
4.0 OHV
Yeah the stock tranny crossmembers on RBVs are pretty crappy when it comes to trail obstacles. They tend to hang down and get caught up on stuff and bend easily.
Many of the aftermarket crossmembers like the one James Duff makes do not have this problem. It's probably better that you made your own rather than replace it with the stock part, considering the use of the truck.
I have been surprisingly lucky with mine. (Knock on wood)
