Creaking? Help!
Pagemaster
Santa Clarita, CA 91387
3.0 Liter V-6
Occasionally when im breaking while turning (slow turning like into a parking spot or into my driveway) i hear a creaking coming from my truck. is this cause for alarm?
Ranger Kip
10
Wellsboro, PA
Ford Fleet
3.slow
Confused and Intolerant
bearing or CV joints
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
I would be more inclined to think its a seizing tie rod end or ball joint.
Pagemaster
3.0 Liter V-6
as i already explained to Ranger Kip, im pretty knew to all the termonalogy, so some clarifiaction would be welcomed. i really have no clue what your talking about. :/
Pagemaster
3.0 Liter V-6
or does anyone care to tell me how to check these things?
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
The balljoints connect the steering knuckle to the upper and lower control arms.
The tie rod ends connect your steering rack to the steering knuckles.
The easiest way to check this is to have someone slowly turn the wheel back and forth while you listen to the balljoints/tie rod ends with a mechanics stethoscope. Where you hear the loudest source of noise is where the problem lies.
If they are seizing they will need to be replaced.
martin
26
St Bruno, Quebec
1991
If you have a limited slip differential, they will sometimes make strange noises when you are turning at slow speeds.
pillen140
45
winston-salem, NC
if its in the steering, do what sasquach says to do. if its braking, could be a brake caliper or slider is sticking as well.
ragajungle
Burlington, WI
2.9L V6
bcost882
5
The Queens Country.....
3.0L, 1.6L
i get a creaking sound when i turn it might be say a cab mount.
Tedybear
Firefighter
13
1994 Ford Bronc
5.8v8
Failing is easy. Everyone can do it.
Take it to a shop and ask for one of the under car checks. Most shops do this still for free in the hopes you'll have them do the repairs.
Could be any number of things- including any rubber mounts used that have dried out a bit. Best for piece of mind to get it checked.
S-
bcost882
5
3.0L, 1.6L
i can see shackle bushings or leaf bushings cause it comes from behind to under me
