2.3L ('83-'97) Crank but no start
SebassTurtle93
California
Ford ranger xlt
Hello there guys.....I have a 93 ranger xlt 5 speed & I have replace the ignition control module & coil packs, fuel pump & fuel fliter as well as the ignition wires & spark plugs & o2 sensor but my truck will not start.....i recently took it to the shop & they changed the crank shaft positioning sensor & the truck turn on & while I was driving it to my friends house the engine started bogging on me as if it wasnt getting any fuel but it was still running until I got to the corner of my friends house & the truck shut off on its own so I left it there & the next day I went over to start it up & it turned on but was only able to drive it down a block when it shut off on me....did any of you guys experienced this situation before & if so how did you guys fix the situation
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,620
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I would forget that you just replaced a bunch of stuff... just because it's new stuff... doesn't mean it's working stuff.
You will have to start at the beginning... Spark Fuel Compression... you need all three.
Being it will start and run... I would probably go right to the fuel system. Ensure you're getting proper fuel pressure as your first step.
SebassTurtle93
California
Ford ranger xlt
I appreciate your response.....I'm out to buy a compression test thank you
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
What ole gumpy said. New parts are often dead out of the box.
scotts90ranger
4,541
Dayton Oregon
2.3 Turbo
yep, crap shoot on new parts anymore...
fuel pressure would be my first guess as well, fuel pump could do it.
