Cluster with tach, how to wire
2drxploder
436
usa
ranger
347
lower
235 on 15s
As part of my v8 swap I took the cluster with tach(from 98 expo 5.0) truck originally was 99 2.5 5spd, (no tach) the tach seems to be off bad, how do I fix this?
8,370
Only Pin 16 of the 16-pin grounded ==> V8
Only Pin 8 of the 10-pin grounded ==> V6
Neither grounded ==> 4cyl
So your 2.5l wiring would not have either 16 or 8 grounded most likely
So you would need to add a ground to pin 16
But since it was a No Tach cluster it may have pin 8 grounded and you can just move that over to pin 16
But in any case make sure pin 8 is not grounded and pin 16 is, for V8 tach
I think there were other wires that were different on explorer cluster, the status/warning lights, so posted Ranger wiring below, I don't have explorer wiring
2drxploder
436
usa
ranger
347
lower
235 on 15s
Thanks @RonD ill give it a try in a few minutes after I eat lunch. I was originally told to move 8 on 10 pin to 1 on 16 pin that did not work
8,370
Thats odd, C214(16 pin) 1 is OD light on/off, Transmission control, if you have an automatic I would hook that back up, the original wire that was there, but grounding that pin should have turned ON the OD off light
Most status/warning lights get 12volts with key on, and are grounded to activate that bulb
So maybe explorer cluster is different for that pin
2drxploder
436
usa
ranger
347
lower
235 on 15s
Expo was auto, using a t5 in my swap tho.
I tried pin 8 from 10pin in pos. 1 and 16 of 16 pin, no changes what so ever. Broke a test light which can indicate +/- pin 8 wire (black/yellow) is not a ground
8,370
The pins are for Ranger clusters, so not sure how they apply to Explorer clusters
2drxploder
436
usa
ranger
347
lower
235 on 15s
Ok then ill put stock cluster back in for now. I have a glo-shift tach from another project where should I pull tach signal from for it?
8,370
Tan/yellow wire on pin 15 of the 16 pin connector has the tach signal, you can leave it connected and just splice to it
Not sure what model of glo-shift tach but most use a Green wire for tach signal IN, so that would hook to the tan/yellow Ranger wire
Rest are 12v power and lights, and then a ground
A 1996 to 2003 Ranger cluster with tach would be plug and play, with correct ground for V8 tach of course, lol
2drxploder
436
usa
ranger
347
lower
235 on 15s
Thanks Ron, im looking for a cluster now.
No members online now.
