climate control vacuum lines
emo666
michigan city,Indiana
2.9
Been checking thru here for days and can't find a good source for the TINY plastic or ? lines that feed the controls for the air conditioning and heating for a 1989 Bronco II. The parts stores have nothing that small in rubber to repair the breaks. Where do I find something I can use.
P.S. I have the small vacuum tank on top the air conditioning chamber in the engine bay. I need to replace or repair what I have.
8,370
Here is a thread with pictures of the lines and reservoir:
http://www.therangerstation.com/forums/showthread.php?t=144049
Wrecking yard would be best source, if you need the whole thing.
But for just repair of a break, a small ID rubber vacuum line can be used.
Cut the plastic line and patch with small ID rubber line, it should slide over the plastic tube
