clamp it or weld it?
PaleBlue90
5
Aurora Colorado
FORD
2.3,2.9 and 4.0
should i use some exaust clamps or weld my exaust? im a high school student, am haveing clutch work and u-joint work done..thats 358$ total. i need a muffler and tail pipe and want to do this cheap...thats why im useing a cherry bomb my friend bought me.:D
BlackBII
Ranger Custom
Truck of Month
984
UT
Either way can work, depends on the situation....
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
Also depends on the muffler manufacture. for instatance, if you buy a flowmaster and weld it into your sysytem and it rust out in 8 months the company won't warranty it because it was welded. Now if you clamp it and destroy it getting it off they will cover it.
85_Ranger4x4
18,022
SW Iowa
Probably won't be an issue with a used cherrybomb.
From here on out unless it is a bolted flange I weld mine, otherwise it seems they always leak or come loose around the clamps when you do it yourself.
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Either use stainless band clamps or weld it, U-bolt clamps are absolute junk and belong in the farthest reaches of hell.
khooper
The weld can crack if the shop you have it done at does a poor job of welding it to the pipes. Clamps can come loose and/or separate from the pipe due to vibration and expansion and contraction over endless heat cycles which can cause leaks. I've had all my aftermarket mufflers welded in place and I have never had a problem with doing so over my many years.
_________________
Autopartswarehouse :not_i:
PaleBlue90
5
Aurora Colorado
FORD
2.3,2.9 and 4.0
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
I agree it is just that I was burned for that simple fact with a flowmaster.
