Cigarette lighter re-install?
James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
4.0L in XLT, 3.0L in B3000
31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
The perfect is the enemy of the good.
My cig lighter was "missing" but actually it was behind the bezel. I loosened bezel, can get to cig lighter, took off the wires, I see how it screws into the base of it, here is issue, the tabs that hold it are worn out so it just pushes through. I'm thinking, if I could find/make a washer the right size, like, fiber, rubber, whatever, because the hole for it is tapered, I could probably get it to stay in there. Am I making any sense?
Then assuming I can get it to stay, which is largely a cosmetic consideration, I'd be nice to get another "Aux 12V" for it, then I'd have two. I don't need the lighter. It works though so there's power to it ok.
scotts90ranger
4,375
Dayton Oregon
2.3 Turbo
Yeah, on my original dash bezel thing that was broken on mine and that's where I plugged in my GPS and one day it pushed inside the dash... My fix was just to find another bezel, it's a simple install and all you need to look for in the junkyard is a similarly equipped Ranger or Explorer (all trim levels change drastically on this piece...) from '95-2011 on Rangers and I think '95-01 on Explorers. Rangers to have that port there will need to be 4x2 or 4x4 with manual transfer case (4x4 switch was there I think...) and explorer would need to not have a rear wiper I think unless you don't mind a knob on the other side of the radio...
To get the bezel off you just have to pull the 2 screws under the stereo then pry out on the bezel, the stereo and everything will come with it as you probably already know if you found the lighter socket...
I would imagine you could just put a couple washers there, lighter sockets just screw together and usually have some extra room for things...
