2000Ranger3.slo
- Nov 21, 2009
- 0
- Ford
I have searched for this problem all morning no luck.. 2000 3.0 4x4 5spd. My truck has been running fine no starting problems. I parked it yesterday for a while and went back to crank it: Turn the key on all dash lights come on and fuel pump comes on, however>> Fuel Pump will not shut off, Check Engine light goes kind of dim and flickers slightly and the Theft light is flashing faster than it normally does, the engine turns over but no start.
Normally, turn he key on fuel pump and all dash lights come. Fuel pump primes and shut off, check engine light is bright and will then go out and truck will crank fine.
It is so intermittent there is no rhyme or reason as to what the deal is. Please lend some knowledge. Thanks
