Carbureted Small Block in 98+
ap3x
Northern IL
Mazda
I've been going back a forth on build projects for a 2wd summer car/truck. I know I'm going to want a 302 with +/- 350hp in whatever I build. It's going to end up being an RX-7, Miata, or 4/5 dropped 98+ Ranger. What I'd like to do is pick up a block for cheap, bolt it up to a stand, and gradually put it together when I have the extra cash. That way I can have an engine ready to go so when the right roller comes by I can pick it up and know what I'm doing. Gas mileage and reliability are not factors on this build, and I want to build a carbureted engine. I would think that dropping a carb'd 302 in a 98+ Ranger and firing it up would be pretty simple. I would just use a set of custom gauges, pull the engine light, etc. and call it good. Am I wrong? Should I be pulling a 5.0 EFI out of a 'sploder at the junkyard instead?
Teddyzee
December 2011 STOTM Winner
MTOTM Winner
15
Nova Scotia Canada
5.0L HO, GT40 heads, GT40 intake, 65mm TB, 1.7rr, Tri-Y headers, dual 2.5" exhaust, Flowmaster muffl
You can carb the Explorer engine if you choose.
Oh, and two birds with one stone: Carbed Explorer engine in '85 RX7 :)
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
/sex
Sent from my SGH-T499 using Tapatalk 2
3,614
85_Ranger4x4
18,002
SW Iowa
How fair is it a itty bitty RX7 has room for a mechanical fuel pump and a block mounted oil filter but a much larger pickup does not? :annoyed:
ap3x
Northern IL
Mazda
I'll buy it!
Teddyzee
MTOTM Winner
15
Nova Scotia Canada
The oil filter IS the short one, though :)
And a mechanical fuel pumps fits a Ranger in the real world. It's only on the internet that it doesn't fit.
85_Ranger4x4
18,002
SW Iowa
And here I was thinking my truck was real :bawling:
Between the oil pressure sender, oil filter relocation hoses and steering box there is too much going on there even before the power steering pump entered the mix.
Teddyzee
MTOTM Winner
15
Nova Scotia Canada
You're right.
Regarding a mechanical fuel pump I want to clarify that I read for years that it wasn't possible in a Ranger. Then I read that you could use an upside down pump from an Econoline application. Then, in recent years, I've seen pictures of Rangers with standard mechanical fuel pumps fitting and functioning just fine. I'm sure, like everything else, there are many variable involved, but definitely appears possible.
