2.5L ('98-'01) can you help me what is this hose?
8,370
Is part of it a Grey hard plastic hose?
If so it goes to the Heater hose By-pass valve, has 4 heater hoses connected to it, yes a vacuum hose
End often broke off so rubber hose was used as a "patch"
Other end runs thru firewall and goes into the cab under the glove box next to passenger side kick panel
It changes to a White hose in the cab
There will be a black hose running next to it, this is a main vacuum hose from vacuum reservoir in the engine bay, it runs the cab vents, defrost, panel, floor
The white/grey hose only has vacuum in OFF and MAX AC settings, so not "a vacuum leak" as far as engine or cab vent system is concerned
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
Looks like HeaterByPassValve+Actuator where this VacHose connects is near bottom of your 2nd pic above.
noisyboyy
Firefighter
7
california
ford / ranger
awesome thank you both . I will look again but i didn’t see any place to connect it . there were no nipples or places to connect hose . I will look tonight when i get home . thank you both for the quick response
8,370
noisyboyy
Firefighter
7
california
ford / ranger
great thank you so much . really appreciate all the help guys
noisyboyy
Firefighter
7
california
ford / ranger
RonD , Dillard000,
thank you both so much . I found the where the connection for the hose went . the valve nipple was hidden by a hose so couldn’t see the nipple . the info and pictures got me right to the fix . thank you both for the info and pictures . I really apprecaite it .
Ty
