can i convert my 2.3 turbo carb block over to FI??
85DANGERanger
franklin, in
just bought a 79 2.3 carbd turbo engine and found out there junk with the carb, can i use the newer fuel injection parts (83'-88') on this block?
85DANGERanger
franklin, in
someones gota know something
feellnfroggy
28
Knoxville, TN
85DANGERanger
franklin, in
i im hearing they wernt reliable. the carb and turbo wrnt hard to tune together and theres no performance aspect to these early carbed turbo 2.3
fastpakr
2,834
Roanoke, VA
Megasquirt. Anupaum is a great resource at TRS for that, as I recall.
85DANGERanger
franklin, in
ive been over there, hardly enyones ever on overthere
fastpakr
2,834
Roanoke, VA
What specifically are you looking for? There's tons of documentation available on Megasquirt and a pretty sizable user base to bounce ideas and questions off of. Having a precise question will help you with getting answers.
85DANGERanger
franklin, in
i got the 2.3 turbo block, i need everything to make it fuel injection, upper/ lower intake, throttle body, injectors, turbo exhaust manifold, turbo tubes, wiring harness, etc.
Mutant Pony
9
Hersey, Mi
2300
With the right parts and knowledge it is no problem to convert it to EFI.
Who ever is telling you that you can't make power carburated has no idea what he is talking about.
Wicked_Sludge
43
Westport, WA
3-point-GO
it can be done...but with the number of parts your going to need, you might as well just sell the carbed engine and buy a FI turbo donor instead.
you'll be replacing basically everything but your block and head to convert, and additionally you'll need the engine wiring harness, PCM, and fuel system.
Psychopete
29
FW, IN
+1, not only that, it's good to have a good running donor. Say you get it all together and something isn't right, it's going to be a lot easier to diagnose since you knew everything worked properly before hand. If you throw on a bunch of junk yard parts and cross your fingers... It could turn into a bad nightmare (and probably cost more).
Pete
BlackBII
Ranger Custom
Truck of Month
982
UT
Yeah, there is nothing wrong with a turboed carb setup, just needs to be tuned correctly.
If you want to go FI, it would be easier to find a complete donor car, like mentioned.
Look for a 87-88, as they have the bigger VAM, better ecu etc.
85DANGERanger
franklin, in
i wish i could come across a donor 2.3 turbo, people say there dime a dozen, but come on, we all no there not. ive searched every page of the net for parts or donor cars, cant find nuthing.
Bill G
4
A $20 fuel surcharge from Tucson
1984
2.3, 2.8
You are not trying very hard. Enter your info at this site.
http://www.car-part.com/index.htm
I ran the area from your profile and found five engines. You should look at RPS, turboford.org, craigslist and ebay for parts.
