ActuallyaMazda
- Mar 16, 2024
- 38
- Olympia, WA
- Mazda B4000
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 4WD
- Tire Size
- 33’
Hi everyone. I’ve got another issue on my B4000 that is getting worse as time goes on. I have solved my previous issue with high idle and rough warm starts. Turned out to be the PCM, so I ordered a remanufactured one. It dropped right in and immediately the high idle went away, however I am having a new slew of issues. Hooray!
First off, with a new PCM swap, I installed it with the battery cables disconnected. First startup was a dream. It started up at the RPM it should’ve, and held itself at about 750 when it got warm. That’s fantastic and everything and so I took it out for a drive. I took it at least 10 miles so the PCM could relearn all the values. Got back and parked it and noticed that it had a slight misfire. Drove it to work the next day and the misfire seemed to get a bit worse and now it started to backfire under slight load (anywhere from idle to about 2500rpm). This was all at the start of this week. Fast forward to this weekend and I have replaced spark plugs, wires and ignition coil all with as close to OEM that I could have our parts department order me and it only seems to have made the problem worse. It idles like the IAC is unplugged at about 350rpm and sounds like it is only firing on a cylinder or two. The rest is lopey, sputtering backfire noises out the exhaust.
I don’t have a catalytic converter on this pickup, so I am also clearly able to see the tailpipe spitting out puffs of smoke at idle.
In the process of yanking out my spark plugs this morning, I noticed that on cylinders 4, 5, and 6, the plugs were black and wet while 1, 2, and 3 were dry and looking like normally worn spark plugs.
I have only taken it on a couple drives since the issue has started because it almost seems to get worse every time. What happens is that accelerating from a stop, it’ll backfire and feel like there is barely any power until it gets to about 2500 - 3000rpm and then it decides that it actually wants to work and will run completely normal. Runs normally under WOT as well. Once it gets back down to lower rpms though, the backfire comes right back and so does the power loss. Parking it after a short drive and it’s warmed up as well, it bucks and shakes the whole pickup at about 400rpm and almost will stall it out and sound like it’s trying to suck every last bit of air that it can through the intake. Unplugging MAF makes it run worse in general, unplugging IAC drops the RPM like it should and will sometimes stall it out, unplugging the TPS as well will make it run worse and also make the smoke out the exhaust worse for whatever reason.
I’ve been dumping a lot of money into this lifted POS for a couple months now just trying to get it to start up and run correctly and before you ask, yes I have checked power, grounds and continuity to all electrical components and they all test within range.
Any advice would be greatly appreciated! Thank you!
