bucket seats in b2
detty_motorsports
chillicothe,ohio
ford/ford
2.9
are there any bucket seats that will bolt in a b2 with no mod's needed????
martin
26
St Bruno, Quebec
1991
I thought the b2's had bucket seats, mine does.
wantaranger
2.9L V6
mine has the 60/40 eith the mini center console that folds down, are you jtalking aboujt the seats that are jujst buckets like you would find in a car or somethin? if so i got a set oujt of an old car not sure what it woes and pujt them in my 88 ranger, now theyre goin in the b2,i might do a write up on it when i put them in, all i had to do was drill new holes
CopyKat
8
Manitoba, Coldest place in Canada
Look in the interior forum. This has been discussed at length and has been beaten to the ground. The search function works, use it!
Other B2 buckets, mustang bucket (I have a set for sale, not in great shape though) Explorer buckets, tempo buckets, just gotta bolt them onto the B2 tracks.
heptofite
62
2.3 EcoBoost
the B2 has stock buckets depending on trim level.
the driver's side bucket is identical to the passenger side seat from the 60/40, just mirrored
wantaranger
2.9L V6
and my old 88 had it, i think she saw an xl or something, it had the auto tcase bujt manual trans and windows, not sure what trim, but the buckets in her were awesome
Clem
Yakima
2002 Ranger XLT
1986 Bronco II,
Ranger-4.0 B2-2.9
If you can find one, 91 Explorers are direct bolt ins.
[FONT=&quot]Tempo/Topaz[/FONT]
[FONT=&quot]All years. Tempo GT's are the nicest. Tilting "pillow" headrest and frequently power lumbar.[/FONT]
[FONT=&quot]Escort/Lynx[/FONT]
[FONT=&quot]1981-1991? GT's again are the nicest,[/FONT] [FONT=&quot]"Halo" style headrest, sometimes power lumbar.[/FONT]
[FONT=&quot](The 'Halo' Buckets in the TRS-2 Ranger are from an Escort GT)[/FONT]
[FONT=&quot]Mustang[/FONT]
[FONT=&quot]Don't bother looking they will be gone when you get there. If you're lucky, look for Mustang GT's. Also halo style headrests on GTs.[/FONT]
[FONT=&quot]Thunderbird[/FONT]
[FONT=&quot]1982-1988, Turbocoupe has nicest seats same as Mustang GT but with tilting "pillow" head rests, almost always power-lumbar, adjustable thigh support, adjustable side bolsters on base. The best factory ford seat (IMHO).[/FONT]
[FONT=&quot]1986 Merkur XR4TI[/FONT]
[FONT=&quot]The front seats from an 86 Merkur XR4TI will fit in a B2, so I assume rangers too, If you drill out the rivets, and swap the brackets from the tracks, 1/2 hour per, the seats I used gave me height adjust, adjustable headrest, lumbar support, much better lateral support, (no more bouncing out of the seatbelt) and they're heated. (Submitted by Merc)[/FONT]
[FONT=&quot]All of these will bolt directly to your factory tracks if you have either Buckets or split-bench.[/FONT]
[FONT=&quot]If you have a conventional bench then you will need to replace your tracks with split-bench/bucket-seat tracks. (Toss your solid bench tracks they are completely different).[/FONT]
[FONT=&quot]You will have to run a Tap through some pre drilled holes in the bottom of the seat frames. The holes are already there but unthreaded.[/FONT]
[FONT=&quot]If you have a conventional cab Ranger you will probably have to use the "halo" style headrest used in Mustangs and Escort GT models, as the pillow style will hit the rear window. This forces the seat back into a very upright position. (and is EXTREMELY uncomfortable) [/FONT]
[FONT=&quot]If you have a Supercab Ranger or a Bronco2 headrest clearance isn't an issue.[/FONT]
[FONT=&quot]One other word of warning Ranger Standard-cab, Ranger Supercab and Bronco II's all have different floor pan profiles and so use different seat tracks, so if you want to put buckets or a split-bench into a std cab Ranger you must get your seat tracks out of a std cab Ranger.[/FONT]
Most others listed only require changing the frame rails.
Ray
Sicktight722
Columbia & Effingham SC
2.9L
you could also cut the 60 seat up to make it a 40 like the other one. I remember seeing it done somewhere but can't remember where. would be pretty cheap and just throw some seat covers over them.
edit: its in the tech section under the interior section
