krugford
- Aug 6, 2007
- 2
- Age
- 41
- Iowa
- Ford
Well, it's not a Ranger, but I just picked up a 1994 Ford Escort 1.9L for a commuter. Good or bad, I picked it up for $800.
The problem:
Lately it's been running hotter than usual. Cruising on the highway, it'll run about 3/4 the way to hot (still inside "normal" range). Come into town and slow down and it starts to overheat. Come back up to highway speeds and it will cool back down a little bit.
There's bubbles in the overflow bottle, it doesn't burn coolant as far as I can tell. There no white smoke and no sweet smell to the exhaust. The oil is not getting any higher and looks good. The old plugs looked fine and I just replaced them anyways. I just flushed the cooling system and replaced the t-stat while I was in there. After driving for awhile and shutting the car off the bubbles will continue for maybe 5-10 seconds and then stop. The coolant will be a little low in the radiator but since I can't find any trace of it going anywhere, it may just be getting pushed back into the overflow, not sure.
The bubbles in the overflow tell me that I've got either a bad head gasket or a cracked head but I don't know squat about this car in general. I kinda figured that either one would result in burning a little coolant but like I said, there not an obvious trace.
Are these 1.9Ls prone to cracking heads? Do I just have a bad head gasket? I'd like to hear some opinions before I go pick up a head gasket kit. Could this be something worse?? I have not yet performed a compression check or a leakdown test.
Thanks in advance!
-krug
And now the mandatory I NEED HELP!!!
The problem:
Thanks in advance!
-krug
