bronco missing
87bronco
my 2.9 in my 87 is skipping already put new plugs cap rotor wires checked for vaccum leaks checked compression some what used a older tester but checked out I am not losing water or mixing with oil I am scratchin my head it skips bad at a idle low on power my dads 83 ranger 2.8 will out run this thing my bronco is completely stock any ideas or help will be appricated
Punctuation is also appreciated.
I would love to try and help you out, but I can't understand the problem or the question because it's just a long string of words with no punctuation to help sort things out.
8,372
When engine is cold, unplug the coil's spark wire, the one going to distributor cap.
Try to start engine, it won't of course, crank it for 20-30 seconds.
Now pull out 1 spark plug at a time, each should be wet with fuel.
If you find a dry spark plug then that fuel injector could be bad.
Test it with OHM Meter, should be about 14ohms, check it's wires as well, red wire should have 12volts when key is on.
87bronco
Ok I will try that
87bronco
found the problem it was a bad connection on the injector
