Bronco 2 tank in a ranger?
David85
BC, canada
Has anyone ever replaced the rear fuel tank in a ranger with one from a bronco2?
We have an 87 ranger extra cab (diesel) that came from factory with dual tanks and the rear had rust issues. I'd rather replace it with a new one and places like rock auto carry them for the bronco. I'm just not sure how well it will fit a ranger frame.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
The B2 tanks are a little tall to fit into rangers, but can and have been done if you have a body lift...
SVT
David85
BC, canada
I don't suppose you can point me to any photos of such a setup? Body lift isn't an option but I wonder if its possible to hang the tank down a little to still get it to fit. I would really like to avoid dealing with a rusty tank even if it means having to make a few minor changes.
cammeddrz
23
Ford/chevy
efi 350vortec
if you look closely a bII tank hangs well below the frame to begin with, i measured it a year ago and i think it was something like 13" but that was a long time ago
feellnfroggy
28
Knoxville, TN
Its larger than the ranger rear tank yes, SVT do you think he can do it with 1 or 1.5 inches of washers? (el cheapo BL) Im curious about doing hte same thing.
David85
BC, canada
After some searching I learned a few things here on TRS, other forums and the web at large. It seems the rear tanks on the rangers were rare even from factory and only offered for about 3 or 4 years in the late 80s. No aftermarket support at all from what I can tell so a used one is the only option for a replacement.
Concerns raised with the bronco II rear tank are not limited to the tank hanging down lower. According to others that have attempted the swap, the filler inlet is aimed right at one of the bed support beams so that would have to be cut somehow to gain the clearance. I wonder if thats what was meant by a body lift being required? Cross member mods might allow for the tank to be shifted forward or rearward to clear the support beam but at that point its more trouble than its worth.
An interesting option I did find was for an F350/F450 tank that one guy used with good results. Here is what he had to say about how and why he used one for his truck:
http://www.therangerstation.com/forums/showthread.php?t=67409
Post #6
Still involved sectioning one of the bed support beams though.....
Had I known this such a difficult problem, I would have tried to salvage the original tank.
Short of that I could just spend a few days rummaging through a wrecking yard until I find something that sort of fits. Think I'll put this one on the back burner again.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Anything is possible, but I had the thought of moving the filler neck up towards the top of the tank, and riveting a blank (cover/filler panel) in place of the old location, and using tin snips to make a new mounting location. Also, if you make the filler neck in the floor of the bed, it should also simplify the install. I'm only making suggestions, as I have not yet attempted this, nor have I assisted in an installation.....Another suggestion would be to get a fuel cell (from summit racing or similar place) close to the dimensions of the framerail opening and make some mounts and go with this setup...
SVT
David85
BC, canada
I had toyed with the idea of moving the filler neck actually. I could probably solder or braze on what had to be done and the larger capacity would be an asset. The truck would probably have an 800 mile range on a good day with that setup.
I think what it will come down to eventually is going to a wrecker with the truck and trying to see how a B2 fuel tank can be made to fit. I have dual tanks in my diesel F250 and they are a wonderful feature.
I was really hoping the bronco 2 tank could fit without having to cut it because they can be found in plastic online. I can modify tin easily but not the plastic....not that I've ever tried mind you. Maybe a flange with a gasket could work as a patch/filler neck relocation...
Could also try asking a local plastics shop what they think since I think its just ABS which is pretty common in just about everything.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
I imagine you can just cut a section out, then silicone/rivet in place which would seal it....
SVT
3,614
B2 tank is the wrong size and configuration. It slings much lower, I think it may be a bit wider, and the filler neck is just all sorts of wrong.
I have heard that if you can find the 19 gallon between-the-rails style E-van tank that those work very well, but still are taller than the ranger tank, so you either need to BL the bed, or get longer straps.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
I know for a fact that the B2 tank will fit with minimal mods, as Bray D has done this swap, and has the build pics to prove it...It is possible, it just requires a little work to get it done, and done right
SVT
3,614
I know for a fact that the B2 tank will fit with minimal mods, as BradyD has done this swap, and has the build pics to prove it...It is possible, it just requires a little work to get it done, and done right
SVT
Got a write up with pics? still looking for and considering options for when I got to twin tanks.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Okay, I stand corrected, kind of. Bray D used an 85 ranger tank from the dual tank option, he does know of a company that still manufactures them, so a PM to him will get you the website. He does state though that a B2 tank hangs down 9 inches give or take below the framerail...Here is his build thread
http://therangerstation.com/forums/showthread.php?t=12686
SVT
David85
BC, canada
Getting an original tank sounds great! I'll drop him a line and see what he can tell me.
