Brake Booster
Tbmitchell
Chillicothe,ohio
Go Big Or Go Home
has anyone done an upgrade or a brake booster swap currently i have a 3/4 ton 44 in the front and a dana 60 in the rear of my ranger and im not sure that my brake booster will handle it...so was looking at other options for my truck and its a 83 ranger
bilzy7
32
Lynn, MA
4.0 SOHC
I'm sure many have but have you thought about bigger rotors, pads, and calipers yet?
trail B2
8
North Eastern Ca.
If you have 3/4 ton calipers the brakes should be plenty big.The brake booster from the early 90s that looks different than yours bolts in and has two diaphragms and applies more power.
cammeddrz
23
Ford/chevy
efi 350vortec
Im using the 1 1/8" piston (stock is 7/8"l) master cylinder from the 1-ton trucks, it cost me $25 from auto zone
trail B2
8
North Eastern Ca.
The 11/8 piston is made for the newer vacuum booster.The smaller the piston the more power in the brakes but the more throw in the pedal.
