Bolting the trans to the engine
SilentShado
Mchenry, IL
3.0 "V" Vin
Update, I got the new engine installed in my truck last night, But then a problem arose. I had to spin the motor so that I could get the tourque converter bolts lined up into the flywheel. It spun fine by hand, later after I had bolted the trans to the motor I needed to tighten the bolts to the torque converter. I tried to spin the motor by hand and no spin, I then tried to spin with a socket and no luck. I took out the spark plugs and tried spinning the motor again and no luck. I loosened the 2 bottom bolts on the trans to engine and it spun over. I am now concerned that this will eventually cause damage down the road if this is left this way.. Any ideas of what this could be and if this will be ok to leave like this?
thanks
CheapThrillB2
May 2010 OTOTM
8
Western Michigan
1975-1995 Ford
FORD
soon 5.8L
your convertor is not lined up in your trans pump all the way
SilentShado
Mchenry, IL
3.0 "V" Vin
Will it be ok for me to drive to the trans shop and have the fix it?
Hardwareman
SoCal
I thought serious damage would happen if the transmission is installed to the engine without the torque converter fully engaged upon install?
I just did a Mercury Mystique transmission and made damn sure the converter was fully engaged into the fluid pump of the tranny. The manual even states that serious damage will incur if this step is not done.
Allen
SilentShado
Mchenry, IL
3.0 "V" Vin
that's what I am trying to find out, not really sure but it fired up and ran. I just didn't try to drive it. The top 4 bolts are all the way tightened, it was just the bottom 2 bolts that i had to turn 1/4 turn loose.
4x4RangerGuy
5
Newton Highlands, MA
Subaru
2.0
Don't drive the truck without the converter securely fastened to the flexplate. Bad things can happen, usually ending with the transmission taking a dump.
As was mentioned before, it sounds like the converter is not seated correctly. You have to wiggle them as you put them on until it "clicks" and seats into the correct position.
SilentShado
Mchenry, IL
3.0 "V" Vin
I do have the 4 bolts attached to the flex plate from the torque converter, the 4 bolts from the engine to the tranny at top fastened securely, I went back outside and tightened one of the 2 bottom bolts securely and turned the motor over by hand "worked this time", i was going to tighten the last one again to see if it would work but I did not want to drop the starter motor tonight. I will try tomorrow, I will also make sure the 4 bolts for the torque converter to the flex plate are tight still after tightening the 1 lower engine to trans bolt. I sure as hell hope this works as I have the whole engine buttoned up except that 1 bolt, I really don't want to have to remove the engine AGAIN... Probably would be easier to tow it to a trans shop and have them realign everything if it doesn't work.
SilentShado
Mchenry, IL
3.0 "V" Vin
One more thing I read that once you tighten the first flexplate bolt to the torque converter it should bring it in 3/8 of an inch, about what I was off I am assuming, that might be the reason that I could get that other bolt on last night. It seems that the convertor is seated pretty close. Do you think that from me starting the engine it could have popped in place or could it be from me installing the torque converter bolts to the flexplate?? I wanna drive this thing tonight
Thanks everyone
AllanD
TRS Technical Staff
134
East-Central Pennsylvania
1987... sorta
'93 4.0
When installing an automatic transmission you start by inserting the torque converter into the trans.
There is enough clearance so that when the engien and trans are bolted together the torque converter can be rotated independently from the flex plate to align the two together....
If you did it some other way, it's possible, even likely that you dammaged the front pump in the transmission.
AD
