Ish
- Nov 22, 2022
- 1
- Virginia
- Ranger
TL;DR: I need a 2.3L Duratec or something to take its place.
I recently picked up a 2005 Ranger (2.3L auto) knowing it didn't run, but the body and all is in pretty good shape. The guy said it died on the highway, didn't make any weird sounds, just sputtered and died (Whatever you say, pal). It smelled strongly of fuel when cranked (though it did sound low on compression on a cylinder or two), so I figured it was a simple fuel line leak. Sure enough, a mouse had chewed through the fuel fitting right above the gas tank, and it was spraying fuel out. I swapped the fitting, and was fairly confident it would start right up.
It didn't really want to start, but it did get going with some encouragement. Barely. There was a real bad misfire and wouldn't stay running. A quick investigation revealed a lot of oil coming out from somewhere, and after I got up under it I noticed a hole in the block. I guess the fuel line was just a lucky coincidence. Not sure what happened to the poor thing but there's no bringing it back now.
I'm on the hunt for an engine now. Local junkyard had a 2007 but someone beat me to the engine. There's a 2010 there too, but it has 230k miles and a suspicious hole in the valve cover, so I think I might have to pass on that one. Calling a few other places local, either nobody has one or they want some crazy number for it (>$2000??). I'm just looking for a beater truck, I don't want to throw too many pesos at it.
So, after that long winded way of getting to it, here's my question. Will any other engines just bolt right in, or am I stuck hunting for a 2.3l? If so, any ideas of where to get a decent 2.3l near Virginia for less than $500 or so? I might just put the truck right back up for sale and try to get my money back, I don't know. Thanks for any help.
P.S. First post and all, but no stranger to a Ranger. I also have a 1984 4WD V6 and a couple of early Couriers. Just not super familiar with the newer stuff.
