Best Oil for 1987 2.9L V6
RolandTrafton
Los Angeles, California
Hey guys. I just bought a 1987 Ford Ranger 2.9L V6. Out of habit, I’m changing the oil.
I’d like to find out what the last viscosity, brand, and synthetic/non-synthetic the prior owner used, but I’m afraid I won’t be able to find out, so I’m going to start from scratch.
If you had a 1987 Ford Ranger 2.9L V6 in California where it can get up to 100 Fahrenheit, and doesn’t really have a winter, what type of oil and brand would you use?
gaz
656
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
I have only ever used 10w40, I did switch to full synthetic in my 87, 2.9L in 91. I wound up in California several years later and added an oil cooler to help maintain happy temps.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
10w30 or 10w40.... whatever is on sale. It's a 2.9, not a very tight tolerance or complex engine. Just change it when you should and it'll run fine on any old garbage.
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
10w30 is a more updated formula than 10w40 but they'll both work fine in a 2.9. A zinc additive might be worth using but I've heard that it's less necessary once a flat tappet cam is broken in. Change the oil at least twice a year and use a Motorcraft filter, you'll be fine.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Do unto others then Split-probasti me et chognuisti me
Ditto, 10w30 with FL1A Motorcraft filter. Don't waste money on synthetic or additive. If your lifters are clicking your cam bearing are wore out.
Yellow and slippery.
sheep herder
1,024
sheep pen
If it ain't broke, break it.
2.9? Best to find an oil that will mix well with coolant. :LOL:
