Best bare bones v8 block to start.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
yeah......eff the epa.
snoranger
Professional money waster
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
But back on topic...
The 5.0 is your best choice for an easy fit.
300hp isn't that hard to get out of a 5.0l.
Unless you're trying to build a ton of HP, any roller 5.0l bock is fine.
If you're looking for high HP try finding an old Mexican built, high nickel content block.
Ramcharger90
1,708
N/A na
306, Bcam,
Are you planning to make power or just a 250hp to 350hp build any higher I'd would get a high quality aftermarket block. If not then any junk yard roller block will do if plan to completely rebuild deck etc
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Our police force is all ford edge now. Leftover vic's, and the big beasts are suburbans.
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
My question back on topic... which 5.0 block is best. Did they make a 4 bolt main? Were some blocks better?
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I've got time on my side to get the best block... that's what I'm asking.
snoranger
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
That's not an easy question to answer, it all depends on what you're trying to do:
Pretty much any 5.0 block will handle 450hp all day long.
Any of the older 302 block could probably handle a touch more power... about 500 let's say.
The old Mexican blocks (few and far between = expensive) are thought to be a little bit stronger... I stay between 500-550 max hp.
Realistically, if I was building a 5.0:
400-450 would be my limit on a stock block... any of them, any year, will handle that with no issues. If I were to build a 500 hp or more 5.0L, I'd be looking at aftermarket blocks ( Ford Boss, World Man o War, Dart Sportsman).
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
Fair enough. I didnt know If there were any oddballs out there with 4 bolt mains or thick webbing etc like chevy did with their small blocks in heavier trucks.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Off the wall, but what I would do in your, um, chowdah:
I'm not sure if 4.6 was available in your year, but if it were, my vote would be 4.6 with a centrifugal supercharger.
If you're not in the mood to build a junkyard engine, second option, and one I nearly did before I found the Eaton superchargers, would be to use the 302 crate engine that summit sells. $1850 or so IIRC.
snoranger
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
IIRC, the boss 302 blocks were the only 4 bolt mains. They were only 4 bolt on 2, 3, and 4. The after market blocks are 4 bolt on all 5 caps.
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
4.6 is way too damn big. No way I'm going through that nightmare.
snoranger
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I'm going to machine the block myself... that's enough balls.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Doesn't seem too bad.
No balls.
I beg to differ.
snoranger
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Well if you're going to do a 4.6l, you might as well go with a 5.4L... and if you're going with a 5.4l it might as well be a 4 valve DOHC from a Lincoln Navigator.
