Bent axle shaft
Calypso Ranger
5
Springfield MO
31X10.50
My trucks rear passenger axle shaft is bent slightly. I know it’s not the wheel, it has to be the axle shaft. I have a 1992 2.9 v6 with the 8.8 open diff. I’m having trouble with finding the axle-shaft I need. As well as what and how much fluid I need. If anyone has some knowledge about this, that would be mulch appreciated. Also, from what I understand this is relatively easy for replace correct?
3,614
Very easy to replace. For most of us it isn't even an hour job.
The axle shaft itself is the same from a 7.5 or 8.8, but not the same left to right.
You can get new ones from Rockauto.
Fluid should be 80W-90, get 3 quarts. IIRC it takes a bit more than 2. Also get gear oil specific RTV for the cover. Permatex makes it, it comes in a green and grey tube.
Calypso Ranger
5
Springfield MO
31X10.50
Thanks so much man. I really appreciate it
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I always used ultra black :dunno:
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Same here.
Black, gray, or red RTV all seem to work fine (factory used red on the front 4x4 axle). I would not use blue or clear RTV with gear oil though.
3,614
Same here.
Those work fine if you have them, but the gear oil stuff is supposedly a new formula that should hold up better to gear oil. If I have a good tube of black or grey I will use that, but if I have to go buy some I would get the new stuff.
