jaxboy
- Sep 2, 2012
- Reaction score
- 0
- Make / Model
- mazda
- Automatic
I'm sorry if this is a duplicate, but I'm having trouble getting the forum to accept my post.
My B3000 was cranking very reliably before I replaced the water pump. Now it will only crank by jumping the solenoid. It runs beautifully, and everything works. There is voltage at fuse #24 inside the truck, but no power at the push-on terminal at the solenoid. There is no alarm system. I tried wiggling the gear shifter in park and neutral while turning the key. The only wires that were disturbed when I replaced the water pump were in front of the water pump (they are all reconnected), and the ground terminal of the battery. The battery has a full charge, and the terminals are clean and tight. The fuses in the engine compartment fuse box are good, and I cleaned their terminals.
