B1095 abs code
RavoHimself
8
enfield, ct
Anybody have any experience with this code? Can't seem to find much about about it. What I did find either said faulty wheel speed sensor or the hydraulic abs pump. Either way my abs light is on, brakes work great just no abs
8,370
Your 2003 Ranger has 4 wheel ABS?
P codes are engine, transmission and emission, "Powertrain" related
B codes are climate control, cab electrics, seat belt, and airbag related, "Body" codes
C codes are ABS, suspension, steering, "Chassis" related
I can't find a B1095 code listed
But since you have an ABS light on then could be C1095-ABS Hydraulic Pump Motor Circuit Failure
Which could just be a loose wire on the Electronic Brake Control Module(EBCM).
And braking should work fine, this is only used for ABS, hard stops, so not a safety concern unless you need it :)
RavoHimself
8
enfield, ct
I honestly would rather not have abs anyway. I learned to drive without it. I'll get around to figuring it out. Just too cold to worry about it
