- Aug 13, 2007
- 23
- Illinois
- FORD
- Engine Size
- 4.0 OHV
Using the tech library as a guide:
http://www.therangerstation.com/tech_library/Alignment.html
I've purchased the same magnetic protractor and have a tape measure.
The slab I'll be working on is level for the most part, and I'm fairly confident in my ability to use these items to get it driving straight.
My plan is to raise it and set the jackstands as close to possible to where it'd rest with the tires on. Then strip it down to knuckles to achieve the measurments.
I have moog adjustable bushings on the way with a 0* to 4* adjustment and can be set to a true 0*. I've also got a book with the degree values so that's covered.
My questions are:
1). Anybody ever do this? With what results?
2). What measurement should I concentrate on first? Caster, camber, then toe? I'm pretty sure toe is set last....... Correct?
3). Any other tips or advice to make it easier in general?
All the ball joints and wheel bearings are new, and the TRE's are about a year old. All good brands.
Thanks,
Ryan
My questions are:
Thanks,
Ryan
