KasenLeigh90
- Sep 22, 2021
- 4
- Minnesota
- Ford Ranger
- Engine Type
- 2.3 (4 Cylinder)
- 2WD / 4WD
- 2WD
OK! I'm new here, and new to the ranger/ford scene. Usually a GM person, but I do have a soft spot for early '90's and older Ford Pickups, so please be a dick if you must, but lets not drag on shall we. This is my 1990 2.3L Lima. Has the 5spd, no 4wd. Are the steps on the side factory/an extra add on from manufacturer or whatever? They say "Lund" but they are also color matched perfectly to the rest of the truck. (I don't need new ones, these are both actually solid still after 31+ years, which is surprising for a Minnesota Truck {although this one has been pretty well taken care of} they can handle 200+ lbs with barely a *creak*) Its not often you see a early 90's Ranger on the road up here, in fact 98% of the ones you see are late 90's-00's models. Just curious of what the trim package of this truck is as well, because not all of this truck is original (OBVS). The badges aren't original and some are missing. The seats are aftermarket.
The motor has been replaced, original owners never fixed the oil leaks and paid the price for it, second owner found a 90's fox-body that had the 2.3L in it with 76xxx at the time it was pulled. Obviously the bed bars are new, although I've now removed the lights on top, it has a 3" body lift (it wont for much longer) and in these pictures is sitting on oversized rim/tires (currently not on the truck). Anyway, for being as old as it is in this location (rust capital of the damn world it seems like) this thing is solid outside of the body rust. Frame has ONLY surface rust, I've been under this many times and it looks newer than half the '10's coming in to the shop lately. Its been my project truck for the last while, and while I've been doing my own research on it when I can, I want my finished build to look like it was put together by someone who's not a total asshat. ( Some of the pictures I've included are from the original listing of when I purchased this truck, others are not. ) Any info you all may know about it would be greatly appreciated, along with any cool suggestions for builds.
