- Feb 28, 2001
- 4,424
- Dayton Oregon
- Ford
- Engine Type
- 2.3 (4 Cylinder)
- Engine Size
- 2.3 Turbo
- 2WD / 4WD
- 4WD
- Total Lift
- 6
- Tire Size
- 35"
fix my garbage can and put a new mailbox post in... the owner of a what I'm assuming now is a totaled Nissan decided this for me... I know Nissan because of the driving light block off plate I found beside the road... (the headlight shards and mud flap weren't marked that I could tell...) Conveniently they junked their stuff after the garbage was picked up this morning but it sure was an inconvenience... They sheared the 4x4 post my mailbox was mounted on at ground level, there were 3 tire marks within 2' width in my ditch by the mailbox, tore the axle out of the garbage can (drilled a few holes and 12 zip ties later it'll hold for a while... I'm pretty sure I would have to pay for a replacement through Recology?).
On the mailbox it was mostly just dinged up (somewhat beefy locking unit), some rough body work and it doesn't look too bad, used a digging bar to loosen up the gravel around the old post enough to wrap a chain around the stub and lifted it out with the tractor bucket (conveniently no concrete...), grabbed a 6' treated 4x4 I had sitting around that I got free from something, grabbed a couple 3' long 2x4's and some deck screws and made things happen... Still not what I wanted to spend 3 hours doing on Monday night after work but at least it's done...
Oh, and when I did the shop the county made me pay the fire department like $80 for an address sign, they folded that over and bent up the aluminum angle it was mounted on, of course it tore when I tried straightening it out, I'm not set up for welding aluminum yet so I had to deal with that frustrating aluminum soldering stuff... it'll hold until I pick up some more angle or something else...
