another bed swap question
Explodin' Bryan
Hatton, MO
I haven't seen this one in a search specifically. Is it possible to swap a short (6') bed for a long (7') bed? I'm considering buying a '99-'00 supercab Ranger and the supercabs only came with the short bed. There might be times I'd want a bit more room and wondered if this would work easily--as in a bolt on. Thanks in advance!
hondaxr650
4
Tacoma, WA
I believe you are out of luck. I don't see many long bed rangers but if I remember correctly the extra length is in the front half of the bed and they have a different frame length between the cab and the rear axle. I don't believe they ever made a frame long enough to fit an ex-cab and a long bed. Might be a fun fabrication project though?????
chvlfrk
December 2010 STOTM Winner
MTOTM Winner
31
Niota, TN
Ranger XLT 5.0L
5.0L
235/70R15 front / 275/60R15 rear
Fyi:
Ford never built a Supercab Longbed, but it can be done, BOMK the only mod would be your driveshaft, you would need a 98up Supercab chassis & a 98up Longbed box & rear frame clip, drill out the 8 rivets per side, swap the frame sections & reconnect usin grade 8 bolts & nuts......
Here's a pic of my 99 Stepside that I've altered the rear suspension on and you can see the 8 rivet points & the grade 8 bolts I used to reattach:
There's a thread on one of the Ranger sites of some guys thinkin of the same Supercab Longbed build..............
94 lngbd
7
Lakewood,Wa
2.3l
i have been seriously thinking about it & even boughts a extended cab shell. Will need to make the frame 14.5 " longer between cab back & front of bed. And by the way any 93-2010 LONGbed will work & the long bed is longer in front & behind the rear tire then the 6ft bed
Lee in Texas
Near Austin
2.9 for now
My '86 is in a shop having this done right now. Will post pics when I get them.
